Old 11-07-2017, 01:03 AM   #1526
mavis.d
mavis.d's Avatar
Do they both do it and did it start at the same time on both? If yes, pull and clean the headlight switch by spraying electrical contact cleaner down the shaft so it gets inside while turning the switch back and forth.
If that doesn't fix it, buy a spare set of bulbs and ballasts and replace as necessary. They are not expensive.
No its both, just very slow, so what you sad. Time for some replacements. Do you know what fitments the bulbs are?
mavis.d is offline   Reply With Quote
