Old 11-06-2017, 09:31 PM   #1525
particlewave
Originally Posted by mavis.d View Post
Hi Fred
I have had my set now for about 3 years and while still working the bulbs are very slow to fire up 20-30 seconds. What do you suggest to improve?
Do they both do it and did it start at the same time on both? If yes, pull and clean the headlight switch by spraying electrical contact cleaner down the shaft so it gets inside while turning the switch back and forth.
If that doesn't fix it, buy a spare set of bulbs and ballasts and replace as necessary. They are not expensive.
