Your headlight isn't working because the connector at the rear isn't fully seated. Pull the headlight back out and make sure that the connector on the tray in the fender hasn't broken loose.
The radio shouldn't change the idle unless it's drawing a lot of power. Is it an aftermarket system?
Have your battery and alternator tested.
