Thread: door lights
Old 11-02-2017, 02:37 PM   #11
911monty
911monty's Avatar
Originally Posted by mebeached View Post
thanks there is no power to the dome light . Guess i will pull out the door latch. Had to do the same on hood and trunk.
Before you disassemble doors, Have you tried the door handles on the passenger side to see if the lights come on? It would be unusual for the switches to fail simultaneously on both doors. If the passenger side doesn't work then wiring or immobilizer are more likely?
edit: I see you say there is no power to the dome light. If that is TRUE then the door switches are not the immediate problem. Re read Particles instruction regarding the light.
