Old 10-31-2017, 12:26 PM   #55
JBauer
JBauer's Avatar
Yep, assuming that you trimmed those edges, the 3rd break light "should" be removed...AND it needs the spin locks to REALLY make it sink.
It is all very tight, but a piece of paper should always be used to check gaps, fitments to see if stuff is sitting on each other...should make horrible creak sounds later on otherwise
Take your time and give the TOP some sink time, too
We're gonna be fine.
Yep, I over reacted. It's the parts that need trimmed. Once i put the weight of the hatch, and it's not heavy it seem to rest against the ears that need trimmed. Did you trim your a little at a time? One side then the other back and forth until it went in? Mine doesn't look like it needs much trimmed to me.
