Old 10-30-2017, 09:34 PM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
Hitting the middle/right of the 0 in 180 is normal, especially in traffic. However, both fans should be running with the AC on. The radiator fans are unrelated to the AC condensers, so it should not affect the AC temp. It could be a few things. Check the fuses first, then the relays (see if they click when activated), if it's not that it may be the fan ballast resistor, which is a common issue.
