Old 10-30-2017, 04:26 PM   #10
BRAN
WALDMEISTER
BRAN's Avatar
I would say adjusting the hinges will be the biggest task.
You will see, that the right side hinge may collide with the inner rubber seal and that the screws in general won't always sit in a flush angle. So the work you will face is to correct that stuff and make it proper, what actually should have been done during the design and production phase.
But it is manageable...
chips....hmmm...the paint shop said, the primer was so bad, that the color would chip sooner rather than later...so I got the whole shebang sanded, properly primed and then painted.
