Thread: Coolant Leak
Old 10-30-2017, 12:47 PM   #2
98Sixer
98Sixer's Avatar
Originally Posted by oldskool73 View Post
for the water pump, you want to open the access in the firewall behind the seats (not the one at the back under where the roof folds), then look around the bottom left pulley, that runs the water pump. This is what you'll be looking at when the cover is off, and you want to check #4 http://cdn4.pelicanparts.com/techarticles/Boxster_Tech/05-BASICS-Belt/images_small/Pic3.JPG
Thanks for the diagram link from Pelican, that helps. The problem is intermittent so I dropped it at the shop for them to sort out. Didn't leak or have temp gauge go above 180 on the drive over. Could be an expansion tank issue as well.
1973 914 2.0-Marathon Blue Metallic (Funday Driver)
1972 VW Beetle Convertible-Saturn Yellow (Sunday Driver)
2013 Panamera S Platinum Silver Metallic (Daily Driver)
2002 Boxster 2.7-Lapis Blue Metallic (Don't Even Ask!)
98Sixer is offline   Reply With Quote
