Old 10-28-2017, 06:11 AM   #3843
pkp4911
Originally Posted by xzyfsk View Post
I replaced the water pump, thermostat and housing, sparkplugs, coolant and transmission oil. The belt was already replaced in the last 5k. The plugs and water pump and coolant were original. my 2003 has 49k on the odometer. It runs like new.
Looks good in white with matching wheels and hoops. Would look even better if you went with some wheel spacers. 20mm with extended bolts. Car will handle better too because track is then wider. Great looking car!
Sent from my SM-G955U using Tapatalk
pkp4911 is offline   Reply With Quote
