Thread: 2003 Boxster S
Old 10-25-2017, 09:31 AM   #11
pkp4911
Originally Posted by SteelStroke View Post
Bought for 9.3K Still owe 4.4K. Spent over 8K in repairs/upgrades. Tiptronic.
Asking 10K.
Black with Savanna Beige interior (Typical scratches/small dings for it's year..could use a new paint job.) Pics to follow.
109K Miles
Runs perfect!
New Advance Auto AGM Battery (Less than 1K)
3 oil changes in last year (due to maintenance perfectly clean oil and filter each time)
New coolant tank cap
New Oil Cap
New plugs and all 6 inner plug seals replaced
New clockspring
New Oil Separator and vent lines
New Bilstien B6's all around (less than 1K)
New brakes/rotors (Less than 1K) Pagid Rotors Front ATS Rear Textar pads all around with new pad sensors.
Rebuilt axle shafts (less than 1K)
New headlamp assembly's
NO LEAKS!
Unknown IMS..newer motor installed No detailed info on when replaced. Just know it is not the stock motor.
New SA pump
Continental DWS06's all around less than 1K miles
New Porsche center caps and valve stem caps.
Driver side bottom seat support broken..but still in good shape
Beluga Racing Aftermarket cat back exhaust..purrs like kitten but growls like lion when punched. No cabin drone.
Decats Test Pipes
New rear lower control arm (Passenger side)
Durametric with 2 VIN's left
Aftermarket BOSS audio player
I sent you a PM. No response however. This is likely the best place to sell. PCA might also be something to consider.
Sent from my SM-G955U using Tapatalk
pkp4911 is offline   Reply With Quote
