You are partially correct. No camber problem, just several track days and it is the outer edge of the left front tire. There is a lot of tread left on the opposite shoulder and if you were to switch sides from how I had them mounted, you would be good for lots more life.
They are far from corded, just wear on the outer shoulder, totally safe to use if you switch sides with them.
