Old 10-24-2017, 10:26 PM   #23
Htci
Hello, I’ve been searching for info on safe removal of the g86.2 rear cover so I can attempt a replacement of the brass gear selector bushing(996-303-515-00) as well as seal; slight leak and play at external selector. I have the transmission out for a clutch, rms, and possible ims bearing replacement. After emptying transmission fluid, can I simply remove the rear cover with transmission vertical resting on bell housing? Do I need to make sure it’s in gear or neutral? Will parts fall into the gearbox if it’s vertical? I read and understand your method of realigning gear shafts with a string so if it’s as easy as popping off the cover to work on these parts then realigning I feel I can tackle this job. I’ve worked on motorcycle transmissions and the design of this gearbox and selector mechanism is similar. Thanks for your help!
Htci is offline   Reply With Quote
