Old 10-22-2017, 10:37 AM   #2
M31
M31's Avatar
Originally Posted by KRAM36 View Post
If you look down the inside you will see a rail that the ball pin circled in red rides in. There is a slide that the ball pin snaps into to slide alone the rail. It may just need to be snapped back in and some lubricant added to the rail or you may need a new slide. Part number for the slide is 98656157701.
UPDATE...thanks you were right! Was able to snap that arm back into the slide rail no problem. The other end also slid back onto the pin but the little square retaining bracket was nowhere to be found. Then I noticed a hole which I think is for the rain channels so I stuck my finger down and yep could feel that square bracket...of all the places to go it had go down that hole! Pushing up from below with a toilet snake got it close enough to the top of the hole I could get my fingers around it. Clamshell now back in place level again but not sure why it jumped its track in the first place...maybe the alignment on the top is out but that's a job for another day...
M31 is offline   Reply With Quote
