Old 10-20-2017, 07:26 PM   #10
alm001
01101
Originally Posted by marck View Post
Those are UTQG 300 tires which means they should last about 20K miles. See https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=48&
As noted you got something going on with alignment. If you have more ware on the inside then you have too much negative camber for your regular driving. You probably also have toe a bit off. Sloppy parts can be a culprit but when was the last 4 wheel alignment by someone other than Happy Boys or Fire Rock?
Couldn't tell you! It was before I owned it. Its top of my list now.
alm001 is offline   Reply With Quote
