Old 10-20-2017, 07:00 PM   #20
jakeru
Should the word rebound be replaced with compression? in the above sentence?
Yes, you are correct Steve! "Bump" is also known as "compression damping". I'll edit my post to clarify.
I'm not sure that having non-adjustable shocks is in any way a "feature"... However, the extremely digressive rebound valving of the FSD makes them special.
You can have better quality shocks (e.g., many Konis and Bilstens) revalved, by the way, should the need to change them still hit. They need to be taken apart and usually a service like proparts of truechoice (Koni authorized rebuilders) would be the folks to talk to about this. Koni has a good racing support team.
2001 Boxster
