Originally Posted by MWS
Sorry, I am not quite following your wiring description...
I assume the dash and door wiring (both in and out) thru factory amp has not been changed. Do you mean that prior owner tapped into the outputs of factory amp for inputs to the Alpine? How are the connections made to the Alpine, via spliced RCA or screw terminals? Also, I assume the connection on the back of the CDR220 (socket C1) is still connected and has not been altered?
Alpine amp is using line inputs, spliced into the front speaker wires. The output from the Alpine amp is to the rear speakers. Socket C1 connector is unaltered.
What I want to do to clean this up:
Option 1: Eliminate the factory amp and just wire everything properly through the Alpine amp since its already there.
Option 2: Connect the Alpine amp to the rear outs on the head unit.
