Old 10-19-2017, 09:35 AM   #5
AZ986S
AZ986S's Avatar
Originally Posted by Geof3 View Post
There are two reservoirs. Upper and lower. The lower is a pain in the a$$, but doable. Lot's of sentence enchanting words, removal of the crossover intakes, TB, and partial removal of the A/C compressor is involved. Usually, the main reason the upper is dry is the PS fluid has puked out (too hot and expanding) of the overflow tube, right on top of the engine. Makes a complete mess, and is also pretty difficult to clean up as there are fairly deep nooks and crannies on the top of the engine. I love my Boxster, but Porsche didn't do a great job with the PS design. If you track your car, the issue can be worse.
I ended up installing a metal canister to contain the ejected fluid after chasing imaginary PS leaks and trying to clean the fluid on the top of the engine I used a metal fuel filter (blocked on one end) and a hose connected to the overflow nipple on the top PS reservoir. I do have a UD pulley as well.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
