Old 10-18-2017, 08:37 PM   #24
AZ986S
AZ986S's Avatar
I admire what Chris Cervelli is doing for the dry sump solution, and I had read that post. The problem is that he does not say what the issue is, only somewhat vague statements on how some common fixes don't help, namely, Accusump, extended oil sumps, oil baffles and Dual scavenge pumps. No doubt the ultimate solution IS Dry Sump, but, to what the Radium King said, why did the X51 and all subsequent engines have an additional oil scavenging pump if that is not at least part of the issue? Also, how can an Accusump NOT help, even if oil is pooling in the heads? Accusump also adds a couple quarts of oil to the system, so that certainly helps to keep temps down. So, short of spending $20K on a dry sump system, I'll go with the "band aids" for now
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
