Old 10-18-2017, 11:57 AM   #1
AZ986S
AZ986S's Avatar
Originally Posted by Bebbetufs View Post
I was planning to add an accusump to the system, but since the only data I'v seen says it doesn't help I've decided to drop it.
Could you point us tho the data?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
