Old 10-18-2017, 10:29 AM   #11
Ciao
Ciao's Avatar
Fixed right rear stop light bulb slot in tailight assembly. The bulb kept popping out. The panel and slot housing the bulb were loose and securing them back onto the plastic and carefully squeezing the the slot that houses the bulb in order to hold in place was fairly easy. Now the stop light on both tail light assemblies work fine.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
