Old 10-18-2017, 07:25 AM   #10
Bebbetufs
Originally Posted by Racer Boy View Post
I run my 2002 in track days, and use street tires to keep the g-loads low because of the oiling problems. I also have a sandwich plate which lowers the sump, along with the plate to also lower the oil pickup. While I had it apart, I went ahead and installed the X51 baffle as well.
Nice! Sounds like yours is holding up fine.
How many track days per year? Would you say that fear of an engine failure is the main reason you avoid running at a higher speed potential (sticky tires)? Or are there other considerations you consider important?
Bebbetufs is offline   Reply With Quote
