Old 10-14-2017, 12:33 PM   #5
Lacostas
Originally Posted by marck View Post
I've had some lock issues also so I'm interested in this and I've got questions that may not help anything but...
Is it correct that the lock switch on the dash console is still flashing red after you unlock the driver door with the key? If so that says to me that the central lock/alarm system isn't getting the message from the door that it's unlocked. If you pull on the passenger door handle from inside to unlock that door does the dash lock switch change? Guess I don't know if it's suppose to.
Is the dash switch actually working to lock and unlock?
Yes it stays red. I'm still searching for a solution. Also if I click the dash switch I think it doesn't unlock the door passenger.
Lacostas is offline   Reply With Quote
