Old 10-13-2017, 07:13 PM   #4
Boxstard
Hi guys. Follow this thread.
Autel MD802 vs Durametric (side by side comparison)
For the best of my knowledge, the Autel can clear the airbag light with no issue, but we will let P-wave confirm that.
I personally Owen the Durametric, but the problem it is limited to 3 VIN's only. So it will be a problem to find someone to lend you one.
I for an example, already used all three.
With that said, I mostly use it to read/clear cods, clear airbag light, and run a periodically cam deviation readings.
If the Autel can do that, then it's a better buy for the average guy,in my opinion.
It's not limited to 3 VIN's, and can be used on other none porsche vehicles.
In my case, Durametric did not work to reset airbag light... so I returned it for full refund and got Autel, it works great! Reset it twice after fixing to seatbelt buckle and clockspring issues.
