Old 10-11-2017, 06:30 PM   #20
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by Fuzzuki View Post
I checked. My blower motor is not running.
I just put a glass window top on.
Its really hard to get the top into the correct position to gain access to the motor??
Is there an optimal position for this?
I just replaced my stock roof with a glass window with a replacement roof with a glass window. The new window is a little bigger and I have no idea how I'll get at the engine now. Access is cut in half with the new top when in the service position. Oh well, I just hope things hold together.
You can power your blower motor directly off the battery by pulling the fuse and running a large gauge wire from your battery positive to the fuse holder I pulled the fuse and made the connection at the back of the fuse holder. I did not want to power the upstream part of the circuit even though it would be open, just didn't know what I might be sending power to.
If the fan runs at that point you just eliminated that part of the system (fan and associated power wiring) from the fault tree.
2003 S manual
