Old 10-11-2017, 06:08 PM   #1
Lacostas
Remote keys stopped working at same time after 1.5 days
Hey guys,
I'm having a strange issue with my 2.7 2003 boxster lately. I was driving the car daily and using the remote key to lock/ unlock normally. After 1.5 days, in which I was away and didn't drive the car, it seems that BOTH keys ( initial and spare) have stopped working. Maybe the key ( in my pocket ) was pressed many times ( but not over 1024) and it got toasted? But even so, the spare key should be working fine. Already tried to re sync them ( unlocking door and ignition on, start engine and press unlock key etc...) but all attempts failed. Both keys not opening neither the trunk/frunk nor the doors. Both keys are flashing, when pressed, so I guess it's not battery. I have to manually unlock with key, and even so, it only unlocks the drivers door and nothing else (Passenger door stays locked, gas the same, and the dash lock switch stays red). The alarm system works fine, I also checked the Fuses and they all seem OK (E1,B8,C3). The car doesn't do any diagnostic "beep" or anything else...
Plus, there seems Not to be any moisture under the drivers seat.
I have already done my homework here ( apparently ) but none solutions worked. How is it possible that both keys stopped working after almost two days of car inactivity?
Lacostas is offline   Reply With Quote
