Old 10-11-2017, 06:08 AM   #10
redciv1
redciv1's Avatar
you will have to identify the pins on the board that operates the garage door.usually there are 4, but you will need to use only 2.
what i usually do, is take a paper clip, open it, and use it to create a shortcut between the button contacts.
once you identify which two contacts open the door, it doesn't really matter which one will be connected to the leg #4 and the switch, and which will go to the #1&2.
if you post a pic of the remote i might be able to help more.
if its a liftmaster i might have one.
Thanks Meir, I will get pics of remote today.
redciv1 is offline   Reply With Quote
