Old 10-10-2017, 06:30 PM   #1
AZ986S
AZ986S's Avatar
HID Headlight ID
So I am having an intermittent driver's side low beam headlight issue. Every so often, it won't light up. The high beams both work, but take some time and sometimes set the low voltage light on the dash. I've had the car for 18 months and have had the issue with both lowbeams not lighting up, and have replaced the dash switch and it fixed the problem, until now. I pulled the light out and opened up the cover to find this:
Looks like an an aftermarket kit. Does anyone recognize this?
Is this bulb replaceable?
BTW, which one is the low beam?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
