I had the same problem in my 01 S. I recently flushed the brake fluid and in doing so, I also flushed the clutch fluid and the odd 2nd gear grinding stopped. It used to grind when shifting into 2nd when cold, but not anymore
5280 Cruising @High Altitude
Seal Gray & K&N Filter
