Old 10-09-2017, 10:52 AM   #3786
Troy.Boxster
Originally Posted by Troy.Boxster View Post
I changed the oil and filter (housing and insert) and tried to replace my brake pads and rotors so I can pass my inspection (technically they are fine, but not quite good enough I guess). I bought PowerStop products but the front rotors and pads are smaller than what was on the car already. Amazon, R0ck Aut0, Jegs, and others all say that I bought the right ones, but the PowerStop site lists a different product number!? So, I guess I have some calls to make to PowerStop to figure out what's what. The diameter of the set that PowerStop lists for me actually match what I have on the car whereas the set I bought are about an inch smaller. I don't know if there is a bad flag somewhere that is saying these are good for my 2000 S across all the sites, but I'll post whatever I find.
Luckily, my oil filter looked good and my magnetic oil plug didn't have any concerning particles stuck to it, so the afternoon wasn't a total waste.
So, after calling PowerStop, it turns out that Amazon and some others don't indentify the correct PowerStop rotors and pads for the 2000 S. I don't know where the problem is, but be careful and double-check/cross reference what you are ordering. I thought I had, but I was using the different sites to check instead of going to the PowerStop site.
Anyway, since I was running short on time to get everythying done before my temporary registration expired, I had to go to a local shop to get the work done. After a broken caliper bolt, cracked brake line, and stuck bleeder nipple, I'm golden and glad the shop worked on it and not me. BTW, I think the rotors were original to the car! 17 years and 66K miles later, they are replaced. I've had the car almost 10 years and hadn't had to replace them and I don't think the PO did either (maybe he did, but he didn't provide much paperwork and they sure looked age appropriate). They still seemed to work fine but failed the inspection because the inspector didn't like the look of the pitting and surface rust (worse on the inside, so it wasn't apparent by the casual look through the wheels).
Tomorrow I'll do the reinspection and finalize the registration. The process is a bit annoying, but will be worth it once I hit the unlimited section of the autobahn!
2000 Boxster S - B.A.D. short shifter and intake plenum - 996 throttle body - Fred's xenon projector headlights - blue LED instrument cluster - and a few other things
Driving this car makes me wish I lived farther away from work!
Troy.Boxster is offline   Reply With Quote
