Old 10-08-2017, 11:13 AM   #15
JFP in PA
My preferred retrofit is the LN Engineering IMS Solution, available in both single and dual row configurations. It is an oil fed solid bearing replacement for the ball bearing factory unit, and is the only permanent (never has to be replaced) retrofit on the market. There has never been a failure with the solid bearings as there are no moving parts, and it gets a constant feed of freshly filtered oil. Check LN's website for details.
JFP in PA is offline   Reply With Quote
