Old 10-08-2017, 11:08 AM   #15
jborchel
It is not "what I think", it is what the data says.
And we have seen absolutely no evidence to support your conjecture that "seals will fail due to little use resulting in them drying up, which leads to a brittle seal, which cracks and fails. This is far more likely to be found on low milers than ones which are driven daily". We have pulled IMS bearings out of cars with as little as 6K miles on them on 10+ year old cars, and the seals looked brand new, and were soft and pliable. We have also pulled IMS bearings out of daily drivers with over 100+ miles, whose seals were dried out and cracked.
I've found another Boxster to look at. It has 100,000 miles and is very clean. Can you point me to the new fix that is available? Does this new fix have certain engineered characteristics that substantially lower the possibility of future failure if the car is maintained regularly? Is the fix low enough in cost to do it even if there are no signs of pending failure?
jborchel is offline   Reply With Quote
