Old 10-08-2017, 05:52 AM   #10
rfuerst911sc
A good independant shop that does alignments should either be able to set the suspension alignment correctly OR be able to give you specifics on why they can't . Sorry the reply from your P car shop is not good enough in my opinion .
Regardless on you staying with the springs you have or going back to OEM you are going to need a shop to do a four wheel alignment . Where are you located ? Is there a PCA region where you are ? PCA members may be able to suggest a good indie near you . Good luck .
rfuerst911sc is online now   Reply With Quote
