Follow up: Cruise and OBC work beautifully but cluster gauge indicator for cruise does not illuminate. Still trouble shooting.
Airbag issue solved - fault was caused by the seatbelt retracter sensor/actuator which I unplugged when I removed the enertia reel to run a wire harness to the DME. I reinstalled everything correctly, but neglected to position a small orange button on the sensor/actuator in the "armed" position. Repositioning the switch illuminated the fault.
