Old 10-03-2017, 08:13 PM   #17
boxfix
For curiosity - slightly pressurize the old vac reservoir with it's base under water in a bowl.Look for bubbles and hissing when you elevate it bove the water level. This will be a satisfying diagnosis.
In theory you could epoxy the base of the old leaker. Why Porsche did not use a one piece blow molded part like other manufacturers do ,I have no idea. It would have been a cheaper part too !
sounds like you are saying it leaks at the seam at the base.
I would like to test it, but the old one is still in there. I was not about to R&R the alternator to fit the new vacuum reservoir in. I was trying to meet a CA smog deadline and I knew I had good vacuum now.
So I left it in place and installed the new one temporarily over near the SAI air pump. I will take the old one out when/if i have to change the alternator.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
