Originally Posted by Gelbster
Well done to pass SMog !
The cure for many of the Boxster vacuum problems is silicone hose,brass barb fittings and a Mighty Vac to test the system.Cheap enough but tedious. Your repair will outlive the M96 !
Gelbster I know you have been down the same rabbit hole and you did influence my work.
I bought a new vacuum reservoir and it would hold 15 psi of vacuum. I then hooked the same "mighty vac" type tester to the installed reservoir and it would hold NO vacuum. DUHH......
New reservoir and the hoses connections in the photo the photo let me hold 18 "Hg at idle.
