Old 10-03-2017, 07:55 AM   #12
boxfix
#22 check valve should go in that hole. On my 2003 boxster it would slip out no barbs or ridge to hold it in.
I got a 3/16 brass barbed fitting from the hardware store and some 4mm silicon tubing.
I put the barbed fitting in the hole, and connected the tubing to the other end of the fitting and then the check valve.
I used another barbed brass fitting to plug into the "Y" connector.
Unfortunately the brass fitting into the manifold is hidden here behind a hose. I will try to get a better photo next time I am in there.
I also replaced my vacuum reservoir as it was leaking.
When done I had 18"Hg on a vacuum gauge I installed.
After a month of messing around my car cleared all monitors in 200 miles and passed CA smog!!
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
