Old 10-02-2017, 07:47 PM   #1
boxfix
I had a similar problem and it was a leaking vacuum canister/reservoir and a check valve that fell out of the manifold. you need in the area of 18" Hg in the system for the SAI to work properly.
Make sure you have no vacuum leaks.
Use a vacuum gauge to see what you have.
see: Secondary air pump check valve question
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
