Old 10-02-2017, 07:29 PM   #8
boxfix
Originally Posted by bcinphx View Post
Well it was laying down underneath the intake tube. I assumed that it came out of that hole that does not go all the way through. But is there maybe another place that I have to find to insert this valve into? Or will I have to drill a hole thru into the tube? Trying to fix 0410 and 1411 fault codes that come on (cel) every 150 miles or so..
I had the same problem. The check valve just fell out of the rubber manifold. I inserted a barbed brass fitting from the hardware store in the rubber manifold. This was very tight. I then put a piece of 4mm ID silicon tubing on the other end of the barbed fitting. The piece of tubing was like 6" long and I inserted the check valve into this tubing. Everything was nice and tight and leak proof.
I also found that the black plastic domed vacuum reservoir would not hold pressure.
I took the vacuum line off the installed reservoir and used a hand vacuum pump to see if it would hold vacuum.....NO it would not. Replaced the reservoir with a new one for all of $21 from Partsgeek.
the reservoir is way down under the manifold.......To install the reservoir properly you have to remove the panel behind the passenger seat and take out the alternator. Maybe I will do that later.
I installed it temporarily with a zip tie and longer vacuum line.
Here is a look at the check valve. You cannot see where it goes into the manifold, but it is similar to the brass barbed fitting seen here. The manifold connection is under that big hose behind the brass fitting.
On the lower left in the photo below, the electric solenoid valve is for the transmission cooler vacuum valve. I hooked up the vacuum gauge here to see what amount of vacuum I had. You can see the new high temp vacuum hose installed.....it is MUCH better than the black rubber stuff used by Porsche. Eventually I will replace all the rubber show connectors with brass fittings and silicon hose.
I ended up with 18" Hg which is good. You should have between 15 and 20 " of mercury. My codes went a way and I was able to pass CA smog!!!!!
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
