Old 10-02-2017, 10:47 AM   #6
particlewave
That is where vacuum is drawn from. The negative pressure in the intake draws a vacuum on the line leading to the vacuum reservoir.
That hole that the check valve inserts into should go all the way through the plenum. The SAI needs vacuum, so in that sense it is part of the SAI system.
particlewave is online now   Reply With Quote
