Old 09-27-2017, 09:20 PM   #1
boxfix
I put 87 miles on the Boxster today and the SAI has not yet reset.
I did more testing on the vacuum system with the new reservoir installed.
I am getting 18" of HG at my 1000 feet or elevation. This appears to be a good reading. I tried this before with the leaking reservoir in there and I was getting like 9 "hg.
I wish I had done this test days and miles ago.
You can get a vacuum gauge for $13 from Harbor freight, and a hand vacuum pump for $25 or so.
I used the hand pump to test the reservoir and the good one would hold 15" hg.
Bad one would not hold any vacuum. I kept the reservoir in place and reached in there with 2 long needle nose pliers to remove the hose on the old reservoir. then I put the hand pump with a long piece of silicone tubing hooked to the old reservoir. Sure enough it would hold no vacuum.
I put on connector on the "Y" fitting and use a long piece of hose to hook the new reservoir into the system.
I disconnected a vacuum line on solenoid for the Triptronic and installed the test vacuum gauge there. I go 17"HG which climbed to over 18" when the car warmed up. That was at 830 idle RPM.
So I feel I have fixed the vacuum leaks. I assume I would not have this much vacuum if I had a leak of any size.
I have replaced every bit of vacuum tubing I can reach with 4mm ID silicon tubing and brass barbed connectors.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
