If you remove the seat, I believe you have to disconnect the battery first. Otherwise when the seat is re-installed then your airbag light will be on, and you'll need someone with PWIS or Durametric or other appropriate code reader to get the light turned off. Of course having no power while the seat is out may make diagnosis more difficult.
