Old 09-26-2017, 09:00 PM   #1
Jerry1847
New member, need help with central locking and no ignition
Hi all.
Picked up an 01 booster s project yesterday. Drove it two hours home just fine. Parked on the street for an hour or so then tried to move it to my garage and the ignition is dead. Turn the key, nothing happens.
Symptoms:
Central locking synchronization fault code via durametric
Interior lock button was red while driving
Passenger door will not lock (when locking with key in door or from switch)
Remote led lights but does not do anything when pressed
Double beep when unlocked from drivers door
Clutch is very stiff (needs to be replaced)
When I manually lock and unlock the drivers door then open it, the cluster will light for a sec then go dark (door sensor or Microswitch)?
I can't tell if I activated the immobilizer or what. PO did not have these issues nor did the Indy who serviced it last month. It started just fine when I picked it up. Floor mat is dry as well. While driving the key lock indicator was lit and I hit the button.
I tried to start it windows up, down, top up, down with no luck. Disconnect the battery for 30 min and nothing. I checked the fuses and C3 (40) was blown, replaced that and nothing.
Any ideas would be appreciated. Just want to limp the poor thing into my garage to start fixing her up.
Jerry1847 is offline   Reply With Quote
