Well an update.....I was in New England for a while so I have been away from this Boxster project.
I did go 450 miles and go a P0491 and 0492 code. Today I found that the vacuum reservoir was leaking and replaced that. Luckily I had ordered one just in case....they are only $22.
I bench tested the new one and it would hold vacuum.
Plugged the same test rig into the installed reservoir and it would not hold vacuum.
After idling about 10 minutes EVERYTHING but SAI monitors reset. That is pretty cool without driving the car. Will put some miles on it tomorrow.
Also replaced the driver's door window regulator finally and the window works well.......the old one was really fouled up.
Good day.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
