Well, since you said "Please" - Welcome!
A few more notes....
There are no "cheap" performance mods (see driving classes).
Yes, your engine may be one of the "sleeved" engines and blow up.
Yes, the white smoke is normal.
The airbag light is caused by the seatbelt mechanism.
It it starts running poorly - it's probably your MAF.
Small oil leaks under the rear could be your RMS.
If the windows don't operate properly it's your regulator.
If the top doesn't work - it's likely the micro-switches or cables.
If it beeps when you hit the alarm - you left something open.
No, you can't rotate your tires.
If you need a part - check out sponsors first.
If your trunk is wet - it might be the coolant tank.
The interior sensor doesn't work with the top down - buy the "red clip"
The "clicking" on the clutch is the switch allowing you to start your car.
Don't even ask about Clear Bras versus regular
Don't even ask about "cheap" tires.
Posts about how fast you went or who you beat will not get you much love here.
Anything "RUF" apparently makes your Boxster "better"
Don't expect 911 owners to even look at you
Perfectlap is the one to ask about car care.
MNBoxster probably has most of your technical answers.
Don't get Brucelee started on Corvettes and Porsche reliability.
Randall is a "good guy" and has probably fixed everything there is to fix on a 99.
You should hook up with TriGem2K and BlinkWatt - they're about your same age.
We don't know what Grizzly does - but you don't want to meet him while he's working.
Rail26 is a super ninja leading a potato revolution.
Welcome to our dysfunctional home!!!
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
