Thread: Airbag Fault 3
Old 09-23-2017, 08:11 AM   #2
JFP in PA
Originally Posted by Aviator912 View Post
My car was at the body shop and it came back with the airbag light on..
I have bought a Durametric and it comes up with 3 faults, Fault 3 being the first, saying low voltage or something to that effect.
I assume this means the input voltage to the unit is low?? if so how do I check it, is there a fuse to test first?
The Durametric doesn't appear to be resetting the unit anyway.
Does the light being on result in a MOT fail?
Many thanks
First of all, no scanner will reset a fault triggered by a componet failure until the problem is fixed. Your code is for a fault with the air bag control module, which is either disconnected or has failed. If it needs to be replaced, it will need to be recoded with a PIWIS system, the Durametric cannot perform that task.
