The check valve in question (#7 in the diagram, white/ black plastic part) connects to the rubber intake tube. Each end of the tube close to the plastic intake manifold has a tiny hole where the check valve port inserts to. The other end of the check valve/ hose connects to the vacuum reservoir, not the (carbon) canister. You may have vacuum leak with the check valve disconnected, unless the intake hole is plugged.
