Laso is also an OEM pump here in The Uk/Ireland. I recently replaced mine with this and it was almost identical in every way to the one that came out except the Porsche logo was dremelled off. And a lot cheaper to buy it.
While ur at it, stick in an L&N engineering low temp thermostat and new belt. Check the pulleys for wear and if wear is present they will need replacing as they will wear the belt. This will also be seen on the belt being replaced.
Sent from my Galaxy S8+ using Tapatalk
