Old 09-11-2017, 05:19 PM   #134
nicecar
Be very carefull with the screws. They go into plastic and strip very easily. I didnt use any to of antiseize or watever. The best advice I got was on here....rotate screws counter clockwise until it clicks into original bore then tighten down only to snug. The O- rings do the sealing. Cross your tightening pattern to insure even seating. Disclaimer I am a cook not a mechanic. Good Luck. Still had to bleed air after completion
nicecar is offline   Reply With Quote
