					Originally Posted by  robdelorenzo
				Some of you may be sick of reading this
Absolutely not my friend, you got it all wrong! Anything car related is good to go here. I'm enjoying reading your updates in fact. Sure it will be 10x more exiting to read when you'll finally fixed it tough
Don't give up is all I can propose! Also proposing a pressure test on the system to ensure it is water tight. Slight drop of pressure in that thing and the heat is going to take over and will eventually manage to piss out all of that pink stuff (entirely, if not careful refilling regularly lolll). Got to be sealed correctly.
Just do it!
