Old 09-07-2017, 09:00 AM   #1
ovalbore
FS: random 986 996 smalls from 99 Box, 00 box S, 02 Carrera
some photos: https://photos.app.goo.gl/xzVCsdlWqAJS2VjJ2
I have a small pile of parts sitting around from a 99 boxster 2.5, a 2000 Boxster S and an 02 C2 996.2
Parts located in Stillwater, MN. will ship at buyers expense. Paypal, Square cash or credit card direct accepted (square, has a fee)
-LH Fender, Ocean Blue 986. very good, has scratch 1" $80
-RH Fender, Ocean Blue 986, very good, has scratch 1.5" $80
-Fuel door, Ocean Blue 986/996.1 excellent $25
-LH door 986 complete w/ handle, regulator. clipped harness, no door panel, no mirror. great shape $80
-RH door 986 complete w/ handle, regulator. clipped harness, no door panel, no mirror. great shape $80
- 986 Boxster/Boxster S E-gas throttle body with plenum $60
- 996 C2 e-gas 84mm throttle body (2002) $80
- 986 00-04 stock headers w/ cats $65
- 986 00-04 stock cat mid pipes w/cats $80
- LH 986 996 cooling fan, radiator, mount and shroud. 36,000 miles $100
-RH 986 996 cooling fan, radiator, mount and shroud. 36,000 miles, $100
- 986 996 AC condenser (PAIR) 36k miles. $65
- 986 engine bay blower fan $15
- 986 secondary air pump 99 boxster 2.5 $45
- 986 996 blower motor final stage unit resistor pack $15
- 986 996 HVAC stepper motor $10
- 986 996 wiper assembly with motor and wiper arms $35
- 986 996 brake master cylinder $15
- 986 996 charcoal canister w/ solenoid and check valve $20
- 986 996 factory horns with bracket $15
- 01 boxster S clutch, flywheel, pressure plate. Excellent condition $70
- 99 boxster (996 986) steering column $30
- 986 996 washer fluid reservoir with level sender, pump, filler neck, grommets and wiring pigtails $45
- clutch slave cylinder 99 boxster $25 (clutch line available, but its 6 feet long)
- LEFT REAR suspension arm 99633124508 $20
- LEFT REAR suspension arm 98633114304 $20
- front bumper shock (2) 993.505.015.00 $20
- 986 996 hood release latch w/ emergency pull cable and microswitch $30
- 99 boxster ABS pump $30
- 99 boxster steering rack 36k mi $45
- 99 boxster front control arms (L and R, front and rear) $60
-99 boxster front subframe $35
- 986 front fender liners $60/e nice
- 99 boxster AC compressor 36k good tested $35
- 01 Boxster S AC compressor 150k good tested $30
- 01 boxster S power steering pump tested $35
- 01 boxster S alternator good tested $50
- 01 boxster S intake manifolds $25
- 99 boxster LEFT REAR suspension support cradle/subframe 9863311517R $40
- 02 Carrera exhaust tips OEM $100
- 02 Carrera exhaust manifolds $30
- 00 Boxster S M96 engine block halves (3.2 liter) $1,500
- 00 Boxster S M96 3.2 connecting rods, pistons, crank shaft $500
- 00 Boxster S M96 intermediate shaft $350
- 00 Boxster S cylinder head $500
- 986 996 heated seat switch $10
- 986 996 window switch $10
-986 996 stalks w/o OBC w/cruise $65 gloss, not matte.
ovalbore is offline   Reply With Quote
